View Full Version : 4link questions for 2nd gen TA
79ta462
11-24-2011, 03:03 PM
Hello
Ive been a long time lurker here. I have a project car 1979 trans am with a built 455 oldsmobile. I've been looking at doing the chris alston/chassisworks g-link coil over. I'm wanting to run either a 315 or 335 rear tire, and am looking for advice. I already have a currie crate 9" rear end that is full size and is not narrowed.
Is this possible to achieve without getting the rear end shortened? Is it also possible to run the stock fuel tank or will that have to be narrowed?
badazz81z28
11-24-2011, 03:06 PM
I was told just yesterday that Chris Alstons kit is not yet available. Look in to DSE for a 4-link
ProdigyCustoms
11-24-2011, 05:19 PM
Yes, Chris Alston is not available yet and no firm date in sight. DSE or Ride Tech are you 4 link options. With either you can have your big tires without narrowing your rear end. You will not get that deep lip look most want with the mini tub and wide tires as all the extra wheel will be added to the insdie of the wheel. Making the outer lip the same as a stock size wheel would be.
79ta462
11-24-2011, 05:44 PM
Thanks. The DSE was my first choice but involved too much fabircation for me, as i'd need to have a shop do it which would run expensive (~40 hours install * 100$). So if I read that correctly, I can run the bigger tire with say the DSE but the extra width of the tire might stick out past the rear quarter lip?
badazz81z28
11-24-2011, 05:48 PM
How much work involved did you hear about the DSE kit install? 40 hours??? What about the BMR torque arm? Complete bolt on...
79ta462
11-24-2011, 05:59 PM
Thats what I've read, is this incorrect?
ProdigyCustoms
Yes, if you do not mini tub and run a 315 tire the extra tire will stick out past the fender lip. The Ride tech system is a very easy intall. Bolts inot the body and very minor welding on the axle tubes for upper link brackets.
79ta462
11-24-2011, 06:13 PM
Thanks Frank. Do you have any comments on the quadralink install time?
ProdigyCustoms
11-24-2011, 07:15 PM
Well if the shop is working on a running driving car and delivering a running driving car, R and R ing the interior, refinishing the fabricated areas, etc, 40 hours may be a bit storng but we would not be much shy of that.
badazz81z28
11-24-2011, 07:53 PM
May I ask...Whats going on with it? Being it is listed on the website
http://cachassisworks.com/p-1440-camaro-78-81-firebird-78-81-gm-f-body-g-bar-poly-coil-over-suspension.aspx
badazz81z28
11-24-2011, 08:13 PM
Anyone have pictures of air rides 4-link installed?
ProdigyCustoms
11-25-2011, 04:41 AM
The official answer is it is not done and will be done when it gets done.
ProdigyCustoms
11-25-2011, 04:49 AM
Ask and you shall receive. This is a car we did, car is mini tub with 325 / 30 / 19 tires. And Shockwaves. Same set up for Coil Overs
BMR Sales
11-25-2011, 07:28 AM
Our torque arm kits are 100% bolt-in with no welding or fabrication required and give you the best of both worlds, lateral stability for acceleration traction and centered suspension articulation for bind-free handling. The torque arm is great for street, drag racing, or road racing without compromising any application. We offer kits for the customers GM 10 & 12 bolt or we have a kit including a Ford 9" rear ends housing.
Our Torque Arm Kits eliminates the rear leaf springs, replacing them with a custom upper cross-member, adjustable control arms and adjustable coil-over shocks (SOLD SEPARATELY). Multiple spring rates are available.
It would have been easy to use a Panhard rod for this application but there is nothing better than a Watts link for precise side-to-side axle positioning. Our Watts link pivot is machined from 6061 billet aluminum and utilizes greasable, internally fluted Delrin bushings for a long, trouble-free life. Additionally it is supported in a double-shear fashion unlike other options in the market. The Watts link also allows for rear roll center adjustment giving you more options concerning body roll/grip.
Every component in the torque arm conversion kit is adjustable. The torque arm itself provides pinion adjustability. Control arms are adjustable in length and have multiple mounting holes plotted in an arc to provide adjustment for anti-squat characteristics. Coil-over shocks provide both compression and rebound adjustability as well as spring adjustability. Additionally, the shock/spring combos have multiple mounting holes to allow a wide range of ride heights. The Watts link pivot as well as the links themselves have multiple height mounting positions for changing rear CG location.
Here is a recent step by step install article in Super Chevy for 2nd gen F-Body:
http://www.superchevy.com/technical/chassis/suspension_steering/sucp_1111_bmr_rear_suspension_install_strong_arm/index.html
badazz81z28
11-25-2011, 08:33 AM
After looking at this picture....I see potential major issues with my 2.5" x-pipe exhaust living together with the torque arm and the crossmember of the BMR kit.
