Proforged
11-17-2011, 10:16 AM
For those of you who didn't make it to SEMA, we figured we'd post up some photos of the display subframe that we had in our booth.
We set out to use the best bolt-on parts available in the aftermarket to create the ultimate upgraded stock subframe. The performance upgrades are centered around the all-new Proforged CamberTech Tubular Upper and Lower Control Arms. The geometry-corrected upper arms utilize a 0.90" taller, stock-car style ball joint for an optimal negative camber curve, and the lower arms feature Delrin bushings and a truss-style coil over mount for full shock travel. The Tubular Upper and Lower Control Arms will be available in March 2012.
Here's a spec list on the subframe:
AMD OEM-replacement subframe
Proforged CamberTech Tubular Upper Control Arms
Proforged CamberTech Tubular Lower Control Arms
Proforged Tie Rod Ends, Idler Arm, and Pitman Arm (all of our musclecar steering linkage parts come black e-coated for durability)
Proforged Billet Aluminum Tie Rod Adjusting Sleeves
Proforged Billet Aluminum Sway Bar Brackets
Ridetech Triple Adjustable CoilOver Shock System
Delphi 670 Steering Box
Hellwig Elite Series Front Sway Bar
PST Forged Aluminum Hubs and Brackets for C6 Corvette Brakes
6-Piston C6 Z06 Corvette Calipers
14" Disc Brakes Australia 5000 series two-piece rotors
Right Stuff Detailing Stainless Steel Brake Lines and Stock Height Spindles
Totally Stainless High Strength Stainless Steel Hardware
DSE Camber Shim Track Kit
https://static1.pt-content.com/images/pt/2011/11/threeq-1.jpg
https://static1.pt-content.com/images/pt/2011/11/P1040630-1.jpg
https://static1.pt-content.com/images/pt/2011/11/uppers-1.jpg
https://static1.pt-content.com/images/pt/2011/11/upperpin-1.jpg
https://static1.pt-content.com/images/pt/2011/11/shaft-1.jpg
https://static1.pt-content.com/images/pt/2011/11/lower-1.jpg
https://static1.pt-content.com/images/pt/2011/11/P1040650-1.jpg
https://static1.pt-content.com/images/pt/2011/11/tierod-1.jpg
https://static1.pt-content.com/images/pt/2011/11/rotor-1.jpg
https://static1.pt-content.com/images/pt/2011/11/P1040647-1.jpg
Thanks for looking, and let us know if you have any questions!
