toofun
11-14-2011, 10:12 AM
So I figured instead of listing three separate questions I would lump them all into one since they all have to do with the rear of the car.
I have a 68 camaro with a 9 inch rear Question 1.. The angle of the tranny is -5 degrees, the measurement of the driveshaft approx 3/4 of the way down is -3 degrees and lastly the measurement of the pinion yoke on the 9 inch is right as 0... Is this correct? I get horrible wheel hop and am running DSE 3 inch leafs with non staggered bilstein shocks.. Problem becomes if I have to change that pinion angle I dont see how I can since the DSE collars are already WELDED to the tubs of the axle.
Question 2.. I have been debating going with a 4 link but want to retain as much of the 9 inch as I can ( I may buy a new housing to make install easier) The axles I have dont look stock and have a large M raised on them with the number +53 on it. Someone told me that they are Moser axles which I hope is the case..
Question 3.. The car makes a horrible clicking almost sound only when I am going around turns slowely.. The rear is real squirrely and I do want to go with a 4 link but I dont know what to keep or not to keep of the 9 inch.. This car originally was setup for the drags (from what I can tell by the wheels, long half inch studs, tires, cage, fuel cell, etc.. so I am assuming that maybe this guy went with a drag setup? The car makes unbelievable power but I just cant seem to keep the rear end under control.. Downright scary.. I also believe he went with c clip eliminators which Moser states is a NO NO for the street and should only be used for drap racing straight line applications due to the fact that they will crack on turns and leak.
Thanks in advance!
Mark
TOOFUN
Thanks in advance!
Mark
TOOFUN
