fladoans
11-05-2011, 11:49 AM
SOLD - THANKS FOR LOOKING
69 Camaro Pro Touring Project for sale $14,500.00 for carand all parts.
Totally rebuilt from the ground up 100% new sheet metal. Ihave the entire car – except the motor, with a large number of new parts and 2sets of rims and tires.
VIN# 124379N672114, the car is currently titled in Floridaand has always had a valid registration and Tag. Florida Collector Car PlateANTI097233.
The company that I have worked at for 21 years is going outof business. So I am following another dream of mine and have started my ownbusiness. But, I need the money so another dream has to sacrifice. This car wasbeing built for me to keep and drive and no expense was spared. It was doneright from the beginning, with a lot of help and hints from this forum. Buttimes change and I need to move on.
Build Highligts
Speed Tech Upper and Lower Control Arms
Speed Tech Tie Rod Adjusters
QA1 Coil Over Shocks – Big Block Springs
Moser Engineering 12 Bolt Rear End, Custom Width 55 1/4 “, DifferentialEaton Posi, Gear Ratio 3.73, 33 Spline Axles with ½ x 20 studs, Pinion Yoke –1350 Series, Rear Cover – Aluminum Girdle
Moser Engineering 1’ Solid Body Roll Bar
DSE Rear Mini Tub Kit
DSE Weld-In Sub Frame Connectors
DSE 3’ Rear Lowering Springs
DSE Solid Body Mounts
GW Del-A-Lum Rear Bushings
ATS - ATX Spindles
ATS 670 Powering Steering Box
EMS Billet Hood Hinges
All new Moog front end bushings
A complete list of what was done to the car can be seen anddownloaded at:http://www.doansphotography.com/pics/69_Camaro_Current_Status/69_Camaro_Build.pdf
Current pictures of the car can be seen at:http://www.doansphotography.com/pics\69_Camaro_Current_Status
Pictures of the complete build can be seen:http://www.doansphotography.com/pics\69_Camaro_Build
Email: [email protected]
Cell Phone 305-216-0586
Car is located in Miami, Fl 33189
Build Highligts
ATS - ATX Spindles
