View Full Version : Need MSD 2-Pin Connector
esenior
09-24-2011, 10:32 AM
Does anyone know where I can order the 2-pin connector for a GM HEI distributor to the coil?I've got an MSD 8366 and need to run the wires to my coil, but don't want to re-purpose something from the junk yard. I would rather crimp my own connector, but would also be ok with a pigtail. Thanks....Eric
1969CamaroRS
09-24-2011, 10:40 AM
What about using a standard 2 pin weather-pack connector?
$7.00 for a male/female pair of connectors with pins and seals:
http://www.jegs.com/i/JEGS+Performance+Products/555/10761/10002/-1
Crimping it is another story but can be done if you are careful. If you use weatherpack a lot a specific crimper is nice.
http://www.jegs.com/i/JEGS+Performance+Products/555/80566/10002/-1
esenior
09-24-2011, 11:10 AM
I actually have he crimper and a bunch of weatherpack connectors, but the one on the distributor is different (smaller).
https://static1.pt-content.com/images/pt/2011/09/69CAMAROPT_110924_03MJPG-1.jpg
https://static1.pt-content.com/images/pt/2011/09/69CAMAROPT_110924_04MJPG-1.jpg
1969CamaroRS
09-24-2011, 01:33 PM
Oh sorry thought you meant it was lead coming off the Distributor, thought you could cut off the old one and wire up a different one.
Maybe something like this then:
GM HEI Computer Type Ignition Adapter Wiring Harnesses
https://static1.pt-content.com/images/pt/2011/09/sum850516_w-1.jpg
http://www.summitracing.com/parts/SUM-850516/?rtype=10
esenior
09-26-2011, 05:59 PM
I actually have a harness I pulled at the junk yard, but the wire feels pretty brittle. Don't want to cut corners with such a minor item.
I did finally find someone who sells a pigtal that plugs into the 2-pin distributor connector:
CONNECTOR 9-26811 - Mallory (http://www.iboats.com/CONNECTOR-9-26811-Mallory/dm/view_id.485301)
I think I'll use the junk yard harness temporarily to get the motor running.
