View Full Version : Budget rear disk with a 9"...?
Richz68
06-28-2005, 05:48 PM
I was planning on using a 8.5" 10 bolt for my car, but I ran across a 9" that is the correct width for me with my positive offset C5 wheels.
I was planning on running the '93-97 F-Body rear disc set up on the 10 bolt which is a direct bolt on upgrade for any 10 or 12 bolt rear end. I know that the brackets will not match the 9" ends.
Before anyone tells me to call Willwood, Baer, Currie, Strange and buy their system remeber that I want a budget set up if there is one out there for the 9" rear.
Thanks for any help!
astroracer
06-29-2005, 03:18 AM
Modify your current adapter bracket to fit the 9" or use it develope a new one...
BBPanel
06-29-2005, 09:30 AM
How about the SVO’s Bolt-On Rear Disc Brake Conversion Kit For 9-Inch Fords?
http://www.mustangandfords.com/howto/28733/
Richz68
06-29-2005, 02:04 PM
Good info on the Fod SVO swap!
Here it is at Summit's website:
http://store.summitracing.com/default.asp?Ntt=FMS-M-2300-G+&Ntk=KeywordSearch&DDS=1&searchinresults=false&N=0&target=egnsearch.asp&x=27&y=15
I called Ford Motorsports and the kit is directly off of '96-'98 Ford Explorers! It looks like a junk yard run will net me some chaep rear disc brakes!
BBPanel
06-29-2005, 02:15 PM
Might want to check w/Currie - I thought I saw it priced cheaper through them - and they can/will redrill rotor/axle for different bolt pattern if necessary - still not a bad price for all new parts.
Richz68
06-30-2005, 02:37 PM
Take a look atwhat this guy did:
'69 with LS1 style rear brakes on a 9" diff (http://www.mcspeed.homestead.com/69_Camaro_Resurrection.html)
This is a slick conversion!
