View Full Version : How to swap 3rd Gen IROC Camaro Steering Box into 1st Gen Camaro
Pete68
09-08-2011, 11:37 PM
This is the story of my journey to having a 68 Camaro that does not steer like a school bus.
There are so many problems with the drivetrain and chassis of these old muscle cars, where does one even begin? I had heard about swapping in a faster box from a friend who did it on his 66 GTO 20 years ago so I thought I’d start with this. Pound-for-pound and dollar-for-dollar it’s probably the best change you can make to your old Camaro. And when you are done it’s virtually impossible to tell that the steering box has been changed. I’m of course talking about taking a late 80’s IROC Camaro steering box and swapping it into your first gen Camaro.
The IROC steering box is a direct swap in, with two changes that must be addressed. 1) The input shaft diameter is different but a compatible new GM steering coupler is available, and lets face it, this thing probably needs to be changed anyway. 2) The fittings for the high-pressure and return lines in the next box are metric instead of standard (Why the switch to Metric for GM? Maybe it’s because only 3 countries in the world do NOT use the metric system: Liberia, Myanmar, and the United States of America!...good company indeed, but I digress). More on these fixes below…
If you don’t have a junkyard nearby or won’t go to the junkyard this post is probably not for you. Leave this site and go to another and pay $500 for a new box. However, if you want to save some cash AND have an OE quality steering box, read on…
This swap was performed on a 68 Camaro Coupe with the following specs; your car may be different.
Base model V-8 327, 210hp 2-barrel with Powerglide trans
Power steering car (N40 option, factory installed)
Original GM power steering pump already installed in the factory location (or similar aftermarket replacement, as far as I can remember my steering pump is the same one since I bought the car in 1988)
Parts you will need / Services you will need performed:
Steering Box (Junk yard). In 1985 Chevy launched the IROC Camaro. These cars had “high effort” fast ratio steering boxes. These are the boxes you want. Not only is the box way faster than the old Camaro’s 17.5:1 steering box, but they also ran with less power assist, so the steering is faster AND heavier, which means you can feel the road more and be more connected to the car when driving. Anyone who’s ever driven a modern sports car knows the feeling. Of course installing the IROC steering box will in no way turn your Camaro into a sports car (nothing will) but it will make it more enjoyable to drive.
The best way to make sure you have the right box is to go to the junkyard and find a car that says IROC-Z on the lower portion of the door (Trans Am Firebirds from the same years will also work). On these cars you should find the 12.7:1 “XH code” steering box. You can confirm it’s the right box by looking for the original GM “XH” ID code. The ID code is ink stamped on the aluminum cap (sometimes called the end plug) at the end of the steering box. You will most likely need to clean the end of the cap to verify the code, you can use trans fluid or oil to blot the cap, just clean it enough to read the code. Do not press hard or wipe the end cap, you may wipe off the code and then you won’t know for sure if you have the right box. Code is very faint and looks like this (this particular box is YA):
49160
XH box was available on the following cars with the following options (my understanding is it’s basically IROC Camaros). As you can see from the chart below the XH box is faster, higher effort, and has the same travel (how much the steering wheel turns in each direction).
YEAR CODE APPLICATION RATIO EFFORT T-BAR TRAVEL
1985 XH Level IV 12.7:1 28-34 0.210 Dia 32deg
1986 XH V8 FE2 12.7:1 28-34 0.210 Dia 32deg
1987-93 XH FE2 Level IV 12.7:1 28-34 0.210 Dia 32deg
1968 ?? All? 17.5:1 15-21 0.175 Dia 31deg
I would not order a reman box from cardone, or any other local shop as others suggest…you may not get the fast box, do we really think the guys that rebuild these boxes care if the insides are fast or slow, do they car if the box has the right internals for the car it come on? They don’t, they slam em together and sell em back as reman units. 99% of the people that own these old cars don’t care about the steering and can’t tell the difference anyway. That’s why I highly recommend getting one from the junkyard so you know exactly what you are getting.
Power Steering Pump (Original GM). I just used my original pump that was in my Camaro. If you are not using an original pump I can’t tell you what will work…but maybe others can. I also do not know how to make this work with a LS1 engine, Ill cross that bridge when I do the swap in my car. : )
Power Steering Pump Valve (Junk yard). While at the junkyard it’s important that you get the valve from the high pressure line that comes out of the back of the pump, preferably from the same IROC Camaro that you got the steering box. The IROC steering boxes run at higher pressures than the original 60’s Camaro boxes, approximately 1400 psi vs. 950 psi. The IROC box will need this higher pressure to operate correctly.
To get the stuff you need remove the high-pressure hose from the back of the power steering pump (It’s the one with the big fitting). Then remove the fitting by unscrewing it. If you stick your finder in the hole you will feel the valve but it’s hard to get out. There are 3 ways to remove: 1) use a skinny magnet and pull it out, 2) push it in all the way (compressing the spring) and release quickly and hope that it flies out, 3) remove the pump from the car and tilt it over so it falls out. Obviously the magnet is the easiest more reliable way to go. Here are the parts you need to remove: (See Figure #3). 49161
(you need #5, #6, #23, #24 on the attached image)
This valve assembly will directly bolt in to your original first gen Camaro power steering pump! (Nice to know GM used the same steering technology for well over 20 years, way to go GM!!…no wonder they’ve lost so much market share in that time, hey, our stupid customers won’t notice the 20 year old technology in our cars so let’s not bother changing it… but that’s another story, anyway…)
Steering Coupler (GM). This is the item mentioned above that needs to be replaced when swapping in the new box. It’s a GM steering coupler that will connect to a XH box ¾ input shaft. It is available through GM dealers (part number 7826542). It is expensive (around $80 list) but it is brand new, and hey, the box itself only cost $50 at the junkyard. Be sure to get the attaching pinch bolt, nuts, and lock washers when you purchase the flexible coupling, if you don’t already have them. Flexible couplings attach to the steering gear with a special pinch bolt (#7807271). This bolt can be purchased from any GM dealer. You may be able to use your old hardware too.
Power Steering Hose: High Pressure Line (ANPlumbing.com…my local shop, or your own local shop). When I did my steering box swap I went to the auto parts store and they let me look through the catalog at all the available power steering hoses. I was hoping to find one with the right fittings and length from a different car to use on my 68 Camaro. I bought 8 hoses that seemed like they would work, none did. Clearly off-the-shelf parts were not going to work. I did not feel comfortable using the Lee Engineering adapter on the high pressure line (leaks can catch fire if the oil hits the exhaust manifolds/headers and the pressures are super high), so I knew I would have to do a custom hose.
Good news is making your own hose is easy, I went to AN plumbing which is a local shop near my house in Los Angeles. Check out the how to video on their site: http://www.anplumbing.com (http://www.anplumbing.com/). Click on “Tech Videos”. If the site has changed you may have to look around. How-to video is also on YouTube: http://www.youtube.com/watch?v=8LovY7kedyE. As you can see from the video making your own hose is pretty easy.
Starting with the 1980 model year, the inlet and outlet ports on the gear were converted from old school 45 degree flare fittings of 5/8-18 UNF and 11/16-18 UNS female ports to new-style o-ring connections with 16x1.5mm and 18x1.5mm female threaded ports. Remember, the top fitting near the steering wheel is the return line, and the fitting near the front of the car is the high-line.
Call ANPlumbing.com tech line and tell them exactly what you are doing, they should be able to help, I think you can order what you need to make a hose directly from them. You will need:
1. 16x1.5mm fitting to attach to the steering box.
2. The fitting that attaches on the back of the power steering pump.
3. Power Steering Hose: Im not sure which one I used, sorry, my dad actually went to the store for me so I don’t know, thanks dad! : ) Ask the guys what to use for Power Steering. Im sure they will know (Use your old hose as a gauge for the length)
Of course you could also just use the pressure line adapter from Lees Engineering (http://lee-powersteering.com (http://lee-powersteering.com/)).
Power Steering Hose: Low Pressure Return Line (Classic Industries). Use the existing stock hose that is on your car now (but now may be a good time to replace it if its old). It will work as long as you have the Lees Engineering adapter that sits in the return hose port on the top of the box.
Steering Box Adapters (Lee Engineering). These are the fittings on the top of the steering box, where the hoses come in. Starting with the 1980 model year, the inlet and outlet ports on the gear were converted from conventional 45 degree flare fittings with 5/8-18 UNF and 11/16-18 UNS female ports to o-ring connections with 16x1.5mm and 18x1.5mm female threaded ports.
There are two different inserts (#40620: Pressure, #40630: Return) and he sells them at a great price. Lee Manufacturing, http://lee-powersteering.com (818) 768-0371
Pitman Arm (Junkyard, Craigslist, eBay, or remanufactured units). According to Pozzi Racing (thanks guys) the original power steering idler arm will work but the manual steering idler arm will NOT work. Again, if your car did not have power steering you will need to do more research, start with the link below from Pozzi Racing.
Fluid (GM). Ex GM engineer Jim Shea who posted some great stuff on a Chevelle website (link below, thanks Jim for all the great info) strongly suggested to use GM fluid, the system is designed to work with that fluid. I tend to listen to GM engineers with decades of experience so I paid a few bucks more and got the GM fluid. Part: GM 1050017 (old#) or GM 89020661 (new#).
Flush system: Flush the system by connecting everything except the return line to the pump. Then start the car and let the fluid run out into a jar. Shut of the engine after a half quart or so has come out and then top off the reservoir. Repeat a few times, top off the reservoir and you are done. Once everything is hooked up turn the steering from lock to lock to get rid of air bubbles in the system.
Alignment: Bad toe-in will tear your tires up! Get it aligned once completed. Don’t cheap out and not do this, you will tear up your tires!!
What a great swap, and it looks factory too so even guys with original cars can make this swap and few will notice.
The steering is noticeably heavier and is now 2.5 turns lock-to-lock instead of 3.5, a great improvement! In fact, when I first did the swap it felt strange but of course now I love it.
Some people said turn signal cancelation would be a problem since the steering wheel does not turn as many turns now when turning…huh. Anyway, I have not any problems so I would not worry about this.
I just need to add some caster now, 2 degrees is not enough, Im hoping for 6-8 degrees.
For reference, my information came from others, I merely tried to pull it all together in an easy to read and understand format, hopefully it helps. Serious props to these guys who gathered this data.
Read more:
http://www.carcraft.com/techarticles/ccrp_0901_gm_steering_box_upgrade/index.html
http://www.chevelles.com/techref/ftecref29.html
http://www.chevelles.com/techref/shea_1.html
http://www.pozziracing.com/camaro_steering.htm
http://jeffd.50megs.com/Pump_valve_mod_page.htm
Please keep in mind that these sites may be referring to other models and years, so be careful. My post applies specifically to a 68 Camaro with factory power steering.
Estimated the costs for the steering:
Estimated Costs:
Steering Box, IROC-Z, “XH Code” $50 (Junkyard)
Streering Coupler, new $80 (GM)
Custom high-pressure steering line $100 (ANPlumming.com)
Adapter fitting for low pressure return line $6 (Lees Engineering)
GM Power Steering Fluid $20 (Amazon.com)
TOTAL $250 ish
Feel free to message me if anyone has questions.
Warning: Attempt all of these modifications at your own risk. If you are not sure of your abilities do not attempt these modifications. I am not responsible for any information in this article; it is simply a recap of how I performed this modification. Your vehicle may be different, please consult a professional regarding everything you read here.
Andrew McBride
09-09-2011, 03:50 AM
Great write up!
BMR Tech
09-13-2011, 10:12 AM
Thanks for sharing this info. Lots of great information for those on a budget.
Pete68
09-25-2011, 12:16 AM
Camaro boxes. XH is best.
https://static1.pt-content.com/images/pt/2011/09/Steering252520Boxes252520and252520Codes-1.jpg
Kurtismcm
12-27-2015, 06:19 PM
I pulled a pump and steering box out of a 87 iroc z. I have a 68 Camaro with manual steering and a gen 1 350 engine. Does anyone know what power steering pump brackets I will need?
ixfn
12-29-2015, 04:10 PM
Pete68, good job. No trouble with the steering stops reducing your turning radius? That made it a no-go for me (and others), and I wasn't about to chance it by modifying them; the Grand Cherokee box worked much better for me. I did enlarge the fitting orifice for improved idle/low RPM assist (info here (http://www.gmtruckcentral.com/articles/2013/powersteeringmods/)).
[EDIT] Dang! Didn't realize how old this post was! It only popped up because Kurtismcm brought it back - hope you get the info you're after. Long or short water pump, Kurtismcm?
Pete68
01-04-2016, 09:48 PM
If you look at the chart above you can see the steering stops are actually slightly wider than the original box. Its pretty much a perfect swap. : )
Josue
01-05-2016, 03:01 AM
Glad this got bumped up!!!
At the recommendation of a member on the Pontiac board, I bought a 92 IROC box from NAPA, some adapter fittings, and an IROC rag joint off rockauto.com at the end of the season. Wasn't too motivated to get it done with winter right around the corner, but it'll go on before spring for sure. His install wasn't as in depth as yours, so hopefully I won't have any issues. That's all he uses on his swaps, what he told me to buy, so that's what I went with.
Hopefully I have the right box too, since I went reman. It really annoys me how people always say "just go down to the junk yard and pull XXXX part off yourself and save a ton of money!" like it's that easy. We don't have any junk yards around here dammit! hahaha And the ones we do have, certainly don't have 3rd gen F-bodies sitting around waiting to be picked, let alone old muscle cars. It's all late model stuff, maybe mid-90's at the oldest.
ixfn
01-05-2016, 09:30 AM
From a HotRod article here (http://www.hotrod.com/how-to/chassis-suspension/ccrp-0901-gm-steering-box-upgrade/).
What is not so good for A-Body, early Camaro, and Nova owners is the third-gen Camaro box's limited 64- to 70-degree pitman arm sweep. Compared with a stock Chevelle/Camaro/Nova movement of 87 degrees, this means that bolting in an '89 Camaro steering box drastically reduces the early car's turning radius.
My experience coincides with the article. I measured the turning degrees with a cam degree wheel and figured it would work, but I was wrong! I might have the numbers somewhere if I can find my old shop notebook (manual box vs. stock power box vs. IROC box).
Josue
01-06-2016, 07:46 AM
How noticeable is the drop in turning radius? Did you find your self constantly cursing the swap, wishing you had more turning radius?
Would it affect normal driving conditions? Cruising some curvy roads, sharp bends, auto X'ing, etc. Or are we only talking low speed, off idle, parking type scenarios?
ixfn
01-06-2016, 11:34 AM
I would say approximately -25%, and yes.
I am man that will tolerate many, many inconveniences, but I feel eventually it would have gone from an annoyance to a big safety concern - for instance turning into traffic and it would turn so wide you'd consistently enter the other lane, not to mention the fact that you're compromising the car's overall ability. For those with success with this box, I hope you're getting full lock to lock (to the steering stops), otherwise... well, be careful I guess.
I think the difference lies in the pitman arm length (3rd gen is longer -> shorter stops). Although I tried the IROC box in an 80's Cadillac and it suffered from the shortened radius too (an absolute nightmare with a car that long - took it out the same day), but I think it had a longer piman arm too Sorry, it's been a long time since I monkeyed with all this, but I can take measurements of it all if anyone needs the data.
Josue
01-06-2016, 08:14 PM
Yea, seems to be an endless stream of options with stuff like this...GM parts interchangeability! It gave me a headache trying to narrow it down to what to try! I'll just have to get it installed, and see how I like it. Opinions vary, so I'll just have to form my own. Hell, I know a guy who took the quick ratio box back out of his Firebird because he HATED it! Said he didn't like how you could sneeze or fart and end up in the other lane if you weren't holding the wheel good enough! He prefers the old steering while he cruises.....seems crazy to me!
