View Full Version : Coil-over conversion sleeves
Bjkadron
09-03-2011, 05:41 PM
Hello all,
I am looking for some threaded sleeves to convert my rear shocks to coil-overs to finish up my three-link. The only problem is, I don't have a really common brand of shocks so I have no standard options.
The OD of the shock is 1.64" so I need something about that size (preferably + or - .02 or so) Too big wont work, but too small I can bore to the proper size. Does anyone know of a 5-7" adjuster with this size ID? I cant seem to find specs on most of them.
Any suggestions would be appreciated.
speedy79
09-05-2011, 06:19 AM
This should get you started. I know it take small body springs, but a spacer could be made or maybe with deeper digging you can find a kit that takes the standard springs. But if they have the rate you want, who cares what size the spring is.
http://www.speedwaymotors.com/Bilstein-Small-Body-Steel-Coilover-Kit,6871.html
speedy79
09-06-2011, 06:06 AM
I forgot to mention this kit is made to fit a 1 5/8" body shock.
Bjkadron
09-06-2011, 03:14 PM
I saw that... I'll probably go Aluminum though if I have to machine it. but apparently all Small body shocks are about that.
Bryce
09-07-2011, 04:46 AM
Benjamin,
Just spin one out on the lathe. It wouldn't be that hard. If you want to go with a standard 2.5" spring that will actualy help in machining. This will allow you to keep your wall thickness up and less vibrations while cutting it on the lathe.
Bjkadron
09-07-2011, 01:07 PM
Benjamin,
Have you ever cut threads on a old lathe? Not the best thing in the world. I actually found some for pro-shocks that should fit, and they are about as cheap as I could make them for. Also, I'd like to use the smaller spring, because it is getting to be a busy/crowded place under there...
Bryce
09-07-2011, 01:31 PM
Actually yes, HAHA.
I took a 2" square piece of aluminum 3 feet long. And turned it down to a 1.5" round solid rod then put 1.25" threads on one end then made a female threaded cap for this contraption. Manual feeding tool holder. I think I spent the entire day on that one part.
Bjkadron
09-08-2011, 06:59 AM
Then you understand the appeal of getting something for $30 and making on pass with a boring bar. haha!
Then to realize that it probably won't stay exactly like this for very long, I don't want to invest a lot of time into it. I have plenty of other places to spend more time.
Bryce
09-08-2011, 07:03 AM
HAHA, I love to buy and modify parts. My time is worth something. HAHA. I totally understand.
