JRouche
08-09-2011, 09:42 PM
Had a friend here recently ask me if I had a problem with NVH because I use metal to metal mounts for my sway bars. Got me thinking...
I have a metal bushed sway bar at both ends, my rack and pinion steering has the rack mounted with steel bushings, my front control arms use metal bushings, my watts link uses metal heim end links as does my parallel four link.
So my answer was no, I dont feel ANY of the "road trash". Like small gaps in the road, small pot holes, any heavy lines on the freeway or any of the common road trash thats seen while driving, even small road roughness. I just dont feel it in the steering wheel, floor pan or any other part of the car. Its pretty darn smooth. Like driving on air, and I am, air springs.
So I was thinking because I have air springs if that might be a part of it.
My thinking is a car that has steel coil and leaf springs might transmit alot of the road noise to the body and driver??
It might not be all the other suspension pieces transmitting the road noise to the driver but the MAIN steel part thats suspending the car, the springs!!!
So anytime someone introduces a suspension part on the car how every small the transmission of road noise might be, it sounds and feels like you are driving a tank downtown.
I think the MAIN contributor to NVH is the steel springs. And yes, there are the rubber donuts in between the perch and spring. But anyone that has removed 20-30 year old coil springs know they are super hard and compressed, they dont do much to dampen any vibration or road noise at that point. When new they prolly do ok, depends on the design, they might be good for five years. But there is so much force and the material changes so they become useless for the original objective.
My point? It might not be the other connections of the suspension that cause alot of NVH. It might be better to look at the spring dampening pads or an air spring VS ditching the idea of using metal to metal connections for some of the other suspension parts that could benefit with a stiffer joint, like metal on metal or even some harder bushings like delrin.
I think more work is needed to remove the direct road noise from the steel springs before we ditch the idea of using stiffer joints on some of the other suspension parts. Because I think there is a large ammount of preformance gain to be had with using stiffer mounts on the other suspension parts without sacrificing with more NVH.
Just a thought... JR
