Bow Tie 67
07-25-2011, 06:22 AM
Does anyone have experience using Fusor 108B on Aluminum and or in a high heat situation?
I'm thinking of adding aluminum brackets to an AFCO radiator so I can re-use the 4th gen dual fan assembly. I'm sure the adhesive will be strong enough, but I'm not sure if the heat from the radiator will be a problem.
Yes I know the tabs can be welded but I have the Fusor adhesive and would like to use it.
Thoughts?
Thoughts?
