View Full Version : Lord Fusor 108B question
Bow Tie 67
07-25-2011, 06:22 AM
Does anyone have experience using Fusor 108B on Aluminum and or in a high heat situation?
I'm thinking of adding aluminum brackets to an AFCO radiator so I can re-use the 4th gen dual fan assembly. I'm sure the adhesive will be strong enough, but I'm not sure if the heat from the radiator will be a problem.
Yes I know the tabs can be welded but I have the Fusor adhesive and would like to use it.
Mike Holleman
07-25-2011, 03:34 PM
Matt, I've used quite a bit of Fusor 108 with very good results. I've glued deflectors inside a 9" rearend housing on the Elky that most likely get's at least as hot as your rad. They are still in place. The only time I've had it fail was due to fire. It will burn and it will delaminate when it does. By the way, congratulations on your finish at the Heidts event. Damn good driving.
Bow Tie 67
07-26-2011, 03:49 AM
Thanks Mike hope things are getting better for you.
