View Full Version : 68 camaro ls6, vette accessories with iroc box. what hoses?
s10pro
06-29-2011, 11:06 AM
68 camaro with ls6 zo6 motor all corvette accessories,with iroc steering box.. What did some of you use for power steering hoses from box to pump.
carguy502
06-29-2011, 11:13 AM
Four braid hydraulic line (meant for tractors 4000-10000psi work pressure). Used JIC ends which are the the same as AN, just made of steel. Tractor shops that make hydraulic lines are not that uncommon, too.
Best,
Don
dhutton
06-29-2011, 11:29 AM
Connecting to that Corvette pump is tricky becuase the pulley is in the way. A standard AN connector will not fit. On my GTO I used a pressure hose from a C5 Corvette that I got from Rock Auto for $10. Not sure this will fit an F body. For the low pressure side I just bought an adaptor and used stainless braided hose.
