Van B
06-19-2011, 05:38 PM
I am unfamiliar with the guts of a Ford 9 inch style rear end and have a question on axle seals. I developed a leak with gear lube dripping inside the left rear wheel. I took it apart to repair and am wondering if this looks like everyone else's.
The reason I ask is that when I have the Ridetech 4 link installed my fabricator built the rear end housing rather than buying one from one of the usual companies. It looks like the outer bearing depends on gear lube for lubrication. The rubber seal fits around the outside of the bearing race and fits in the little slot. There was a silicone type sealant used to seal up the rubber seal.
Is there some other type of seal I should have? It does not seem like it is enough to hold back the fluid.
