View Full Version : 79 Grand Prix - Parts Inter-change
robortegon
06-12-2011, 04:40 PM
Hi Everyone,
I was wondering if any had any info on which front suspension parts of other make/year gm parts work on a 79 Grand Prix. Especially the control arms. Any info would be greatly appreciated.
Robert
MADMIKE
06-13-2011, 10:49 PM
The '78-'88 A/Gs(Cutlass, Regal, Monte Carlo, El Camino, Malibu, LeMans...) used mostly the same suspension. 78 is an odd ball year as this year had slightly different spindles and some steering linkage differences from the 79-88 cars. In 82 the wheel studs went from SAE to Metric.
The '82-'04 2wd S series trucks use the same front suspension. With the exception of the sway bar and centerlink being narrower, and one of the bushings in the FLCA uses a 14mm bolt rather than 12. 98-up ZQ8 Blazers using a sealed hub/bearing with divorced rotors and PBR twin piston calipers. All these trucks came with stiffer ~600lb/in front springs.
'82-'02 F bods use the same RLCA. '82-'92 FLCA is the same as well, different bushings. TA/IROC/Z28 cars have the better steering box and thicker front sway bar.
That's the quick and dirty.
nekkidhillbilly
06-15-2011, 03:23 PM
my 1st car was a 79 gp btw
novaderrik
06-15-2011, 10:25 PM
Grand National, Monte Carlo SS, 442, Z/28, Trans Am..
those are just some of the keywords that they use on ebay for anything that fits your car.
