View Full Version : Differential resevoir / overflow tank
69lt4
05-30-2011, 05:34 AM
What are people using for an overflow tank or reservoir on their differential?
It's a DTS 9"
Kevin
69 Camaro LT4 / T56 DSE suspension 9" Baer Budnik........
Ron.in.SoCal
05-30-2011, 08:32 AM
Art Morrison has one in their catalogue....
chicane67
05-30-2011, 10:35 AM
You dont really need one... if it's vented correctly.
If you do, the diff is over full... or even worse, the vent is in the wrong place all together.
I use a -8AN with a length of hose with a loop in it... and a small K&N push in filter.
Greasy63
05-30-2011, 12:36 PM
im also interested in this.....
can we get a pic of ur setup?
69lt4
05-30-2011, 12:53 PM
Drivetrain Specialist put the vent hole in the differential. It's located on the passenger side of the housing. It's party way down the slope of the housing going from the center to the axlw shaft. I had a screw in filter and lost some on a 10 miles drive.
I thought I read that if you have a tru-trac or other you would probably need a tank due to the temps it creates and the expansion of the fluid.
I wasn't sure how much the fluid would expand. A -8AN for some length might be enough. I don't know.
Kevin
chicane67
05-30-2011, 04:15 PM
Take a -8AN... screw it into the housing like this (upper left side of housing) :
https://static1.pt-content.com/images/pt/2011/05/SE2-1.jpg
And then add something like this:
https://static1.pt-content.com/images/pt/2011/05/4223_hdr_2-1.jpg
Vegas69
05-31-2011, 07:02 AM
If his vent is in the axle tube, a K&N won't work under a Camaro. Been there, done that.(Unless you like axle grease underneath)
chicane67
05-31-2011, 10:05 AM
Nope... it sure wont. He would have to use one of those 'spring' loaded' steel cap designs... like:
https://static1.pt-content.com/images/pt/2011/05/image006-1.jpg
https://static1.pt-content.com/images/pt/2011/05/image005-1.jpg
69lt4
06-02-2011, 06:51 AM
My breather hole is in the same location you have the arrow in the picture.
I have a drain hole at the bottom and a filler cap towards the top. I filled the fluid to a hole plug found on the "pig" side. Is this the correct fill height? I just looked at the 9 inch under my neighbors 40 Ford. His plug to check the level is on the side facing the back of the car. It's about half way up simliar location as the fitting welded in the picture above.
Thanks again for the help.
Kevin
parsonsj
06-02-2011, 07:28 AM
James Shipka (the OLC Camaro) uses my fuel vent setup for his differential. It's a bit overkill, but works great. He's got pictures of that somewhere.
dontlifttoshift
06-02-2011, 07:49 AM
is this the one that the guy over on cc.com engineered for big truck applications? where can you get it?
chicane67
06-02-2011, 09:21 PM
Kevin
Yes Kevin, that would be the correct fill level... for a 'wet tube' housing.
The very same... I'd head over to CC and PM him... and see if he can get you one on the side or if he has a perfered outlet for the sale of said device.
Old Style
09-02-2011, 06:28 AM
Whoa, two spots and posted in the wrong one. Here was my set-up?
https://www.pro-touring.com/showthread.php?59273-Ford-9-quot-Rear-Axle-Vent
