View Full Version : Anyone running a Baer Brake system with a Moser 12 bolt, 33 spline and Ford bearings?
dondb
05-26-2011, 04:54 PM
I have a 69 Camaro, and the axles have a 1/8" spacer...is it needed? I don't want to press the bearing on and find i don't need it. i can't figure out how to mock it up. If i press the bearing on and it doesn't fit correctly I'll have to cut the spacer off and reseat the bearing. The baer brake system has you put the backing plate on then press the bearing on and if the spacer is not correct it won't be aneasy fix. Thanks for any reply's !
Don
