View Full Version : 10% Off on ALL BRP LS/Gen III/IV Swap Kits!
BulldawgMusclecars
03-10-2011, 03:16 PM
We also offer their full line of engine swap headers, oil pans, brake kits, and other items...PM or email us for specifics! From BRP's site:
BRP Muscle Rods' line of conversion kits are designed in the cars they are intended to be used in using real LS engines and OEM LS oil pans. This ensures that our kits fit best and positions the motor so you do not have to cut up your frame or your oil pan.
Kits are assembled and welded in our own custom built jigs using Lincoln MIG and TIG welders. Engine mounts and frame mounts are made of tough 1/4” thick laser cut cold rolled steel. Our transmission cross members are made of .125 wall 1 ¾” O.D. tubing or .125 wall 1 ½” O.D. tubing depending on the length and vehicle it’s going in. All frame mounts whenever possible are designed to bolt into the vehicles original factory frame holes. This eliminates guess work on where to position the engine for best fitment of accessory, oil pan, and hedder clearance.
All parts are powder coated in Du Pont silver to match our hedders. Components of our kits are backed by a life time warranty. If any part or bushing fails or breaks, we will replace it free of charge. All you pay is shipping.
If you need any other items to complete your swap, such as a transmission, clutch linkage/pedals, bellhousings (aluminum stock type or Quick Time), clutches, flywheels, etc, let us know.
