View Full Version : Deceleration Thump
kryptik
09-18-2010, 08:06 PM
Hello,
I just finished putting my 70 camaro together; tko600, new driveshaft, currie 9 inch, wilwood disc brakes all four corners...
When I decelerate and push the brake pedal I hear and feel through the body a thump thump thump whenever the brakes are applied. It feels as if it is coming from the center of the car. The car stops very well and I cannot feel pulsing in the pedal.
Any suggestions??
Thanks guys,
Matt
09-18-2010, 10:08 PM
get the car up on a lift and check for fresh rubbed metal. With the TKO I'm willing to guess its the front driveshaft u joint hitting the mid car floor brace.
Vince
67 ls1 vert
09-18-2010, 11:14 PM
Check your u-joints, trans mount, engine mounts, and you u-bolts on your rear end.
TT302Z28
09-19-2010, 05:05 AM
I had his same issue once on a 69 Camaro and it was one of the front leaf spring mounts. I had just bought the car because the former owner was tired of trying to find the problem.
kryptik
09-20-2010, 10:22 AM
Hey I checked the driveshaft; it is free of obstructions and all of the mounts are tight...how should I proceed now?
PS how would I check the leaf spring mount?
Matt
67 ls1 vert
09-25-2010, 07:53 AM
hey Matt, did you ever find the problem?
JEFFTATE
10-06-2010, 04:42 AM
Is the transmission hitting the tunnel or floorboard ?
rohrt
10-06-2010, 05:21 AM
Could the pinion angle be changing drasticly enough with the decelerationa and breaks to cause some sort of bind?
Strap a video camera under the car and take a video of the thing while driving.
Josh
10-08-2010, 04:46 AM
Second on the u-joint. On deceleration the pinion with go downward and possibly change angle enough to bind a u-joint
