View Full Version : Wear pattern rear setup
jtm311
08-16-2010, 03:39 PM
Hey guys what would you say about this wear pattern. I have my backlash set to 6. Not sure if this is telling me the pinion is still to deep?
john
big gear head
08-17-2010, 08:44 AM
The pinion is too deep. Take about .003 to .005 out of the pinion shim and try again. Post pictures again.
JEFFTATE
08-17-2010, 10:03 AM
Yes , the pinion is too deep ..
jtm311
08-17-2010, 11:41 AM
ok here is my problem I have a .006 shim under the pinion now, I also pull the shim out and try again looks the same. The old pinion had no shims at all? I checked the race and it is fully seated. now what?
big gear head
08-17-2010, 02:57 PM
There should be at least .025 shim under the pinion bearing. These rear ends usually have between .025 and .045 pinion shim and usually around .030 to .037 is normal. If you only have .006 then something is wrong. Did you install the bearing race yourself? Are there any shims under the bearing race? Did you check the numbers on the bearing and race when you installed them? Did you use a .001 feeler gauge to see if they are both fully seated?
jtm311
08-17-2010, 03:25 PM
Thanks for the reply, yes I installed the race. However, I first made a set of setup bearing out of new bearings same which came in the rebuild kit. Same thing so I know the race went all the way down, even when I installed the new bearing and race I checked it with feeler gauge it was fully seated. What I find funny is why does the old pinion also have no shims? I'm at a loss two days and can not find anything. Also the backlash is at 6
How bad do you think it will whine if I left it?
John
big gear head
08-17-2010, 05:33 PM
I wouldn't be worried about the noise. I would be worried about the gears wearing out or breaking. Your housing must have been machined wrong when it was made. I would find a way to install a .001 to .003 shim and try the pattern again with about .007 to .009 backlash.
jtm311
08-17-2010, 05:36 PM
I was thinking what if I was to just increase the backlash say to 9 would that not move the pattern to the middle?
big gear head
08-18-2010, 03:57 AM
No, you need to move the pinion out.
jtm311
08-18-2010, 04:02 AM
I had an idea last night, I may take the race out and bring it to a friends shop and surface grind the base by .010 this would allow the pinion to drop by .010. I may be able to go further but have to see how much meat is on the race.
jtm311
08-18-2010, 09:05 AM
Ok I was able to take .010 of the base of the bearing race. I'm now using a .011 shim and backlash at .005
much better?
John
big gear head
08-18-2010, 09:47 AM
That's much better, but why are you keeping the backlash so tight? It needs to be at least .007 unless you are usnig 2 step gears. The pinion is still a little too deep, but open up the backlash a little first and see what happens to the pattern.
jtm311
08-18-2010, 10:32 AM
https://static1.pt-content.com/images/noimg.gifI was not try to keep it tight I had to get more shims so I did now she is set to .008 backlash better?
big gear head
08-18-2010, 10:36 AM
Yes, that is better. You are very close. You can stop here or make it a little better by taking about.002 out of the pinion shim.
jtm311
08-18-2010, 11:11 AM
Thanks for all the help I did drop to the .010 shim I would not say it made a big change but I will keep it that way. Thanks again. Now to weld on the suspension brackets :)
John
John Wright
08-18-2010, 11:34 AM
I like that yellow vs the blue that I used for checking the accel/decel pattern. It makes the pattern very visible.
big gear head
08-18-2010, 11:53 AM
:cool:
CamaroAJ
08-19-2010, 01:15 PM
when you were checking the pattern did you load the ring gear? like putting a pry bar between the housing and ring gear then turned the pinion?
the second pattern you posted looks pretty good, i would run with it.
jtm311
08-19-2010, 01:43 PM
Hello AJ No I did not, however, I applied pressure with my hand to act like a load :)
Thanks just waiting on my Dial torque wrench so I can set the bearing pre-load.
CamaroAJ
08-20-2010, 06:17 AM
before you button everything up you might want to double triple check that just to be 100%. you should be good to go.
dial torque wrencehs are nice. i have used mine many many times but oddly enough it has only been on front and rear axle pinion bearing preload lol.
jtm311
08-20-2010, 05:25 PM
Will do AJ spent the day installing the 4 link brackets.
jtm311
08-25-2010, 05:37 PM
Guys put over a 100 miles on the rear so far all is good no noise posi works real well, I did get on it a little today with the performance 4-link install the car really hooks up.
Thanks again.
John
DarkoNova
08-25-2010, 07:58 PM
This makes me want to do mine. Did you pull the axles out completely or just enough to get the carrier out? I'm having a hell of a time trying to get my axles out.
Matt
jtm311
08-26-2010, 02:39 AM
Matt Yes I pulled the rear because I was also doing a 4-link. Once you pull the C clip those axles should slide out. I could not even think about doing this with the rear in the car.
You can see more of the photos here.
http://melexisfitness.com/Camaro_Pro_Touring/Album8.htm
John
