FatfreeGTO
05-03-2010, 08:05 PM
So I put in my driveshaft today 66 GTO Turbo 400 trans 10 bolt rear.
The body is off of the car. There is absolutely no room to push the driveshaft into the tail-piece of the transmission it is bottomed out when its installed. When the body is mounted will this change and I will end up with some play? I can't really see how it could but I'm not sure. All these parts were in the car when it was taken apart and running fine. If I do need to change it should I shorten the drive shaft, or change the yoke that goes into the tail-piece? Thanks for any help with this. I want to change it before I start to put the body back on which is coming up soon.
