View Full Version : will my 10 bolt hold up?
jknox67
03-17-2010, 04:18 PM
I am wondering if my stock 10 bolt posi will hold up to the lsx 376 that i plan on using? Its about 450 hp and around the same ft lbs. Any help would ba appreciated.
Nessumsar
03-17-2010, 06:51 PM
I have a stock 8.5" 10 bolt behind my 420hp/480tq 383. It is an open diff, so there isn't much strain on the axles, and I have an automatic, but I've beat on her for 2 years without a hick-up.
I don't know if I would be doing clutch dumps with sticky tires with a stocker though...
Taman
03-17-2010, 07:27 PM
had a 475 hp 400 in my TA with a 3.42 10 bolt. I beat the snot out of it for 4 years and sold it for what I paid for it. If you don't use slicks you should be ok. It's when you really hook the tires is when you break stuff.
LSx_88_Ciera
03-17-2010, 09:50 PM
A friend has a 72 Camaro 3350# with a SB 412, 11:1, solid roller and Brodix Track 1s that scattered a super T10 went to a auto and his 8.5 is going strong after several years of abuse. Stock other than a T/A cover, has 4.11s, 28x10.5 ET Streets and South Side bars.
big gear head
03-18-2010, 03:56 AM
Which 10 bolt do you have? If it's the 7.5 10 bolt then it will probably break. The 8.2 10 bolt can be built to handle most street abuse. The 8.5 10 bolt can be built pretty strong and will take a car into the 9s if it's built right. Which 10 bolt you have makes a big difference.
ProdigyCustoms
03-18-2010, 03:57 AM
Huge difference between a 8.2 from a first gen Camaro and a 8.5 from a 70 up car. Your 8.2 will most likly turn to dust if you ever hook it up, or if it is spinning and suddenly hits. But it should drive aroud just fine. I would run it and save for a Moser.
