Blue69Gen1
03-09-2010, 07:55 PM
I recently converted my Ford 9" rear end from the standard iron pinion support bearing housing to a aluminium Daytona style bearing housing. I noticed that the larger Daytona bearing is about 0.25" longer the standard bearing (1.125" vs 0.875"). After re-assembly, the yoke now sits 0.25 shallower on the pinion shaft. This has had 3 effects: less spline engagement ~0.25", the pinion nut now has about 0.25" of unused threads, and the yoke is about 0.25" closer to the tranny.
The backlash is correct (~0.010"), the pattern on the teeth looks good on the drive and coast, I used a solid spacer with shims to get the pinion rotational torque to around 15-20 inch-lbs with 150 ft-lbs of torque on the pinion nut, and other wise the rearend when together without any issues.
The rear end can be run as is, but I was just wondering if this was normal or if I am missing something. Mostly I am concerned with not using all of the pinion nut threads. The end of the nut is where it is pinched for the locking mechanism.
1973 Camaro, 450hp, Muncie 4-speed, 3.73 gears, reguarly auto-crossed with occational track time.
