BigBlockOlds
02-06-2010, 05:25 PM
So I have a bit of a problem and was curious if other's have had the same.
On my '87, I've set the ride height where I think it would look the best. Its not overly slammed, just to where the top of the fender is about even with the top of the sidewall of the tire. Here's a picture:
https://static1.pt-content.com/images/pt/2009/06/IMG_1292-1.jpg
https://static1.pt-content.com/images/pt/2009/06/IMG_1298-1.jpg
However, I noticed that at this ride height I can't compress my shocks enough to get them installed on the studs mounted on the rear end.
The shocks I have are the QA1 Stocker Star single adjustable's. I checked their height against a set of Bilstein replacement shocks I had and they both match perfectly.
So what's the deal here? I thought for sure I've seen guys with G-body's this low that weren't using air bags, etc. Heck, my brother's car isn't much higher than what I show and we didn't have any trouble with his.
Is my only option to find a shorter shock so that I won't be bottomed out? I'd hate to raise the car much more because it just doesn't look right. I measured the distance from the shock stud on the rearend up to the point where it bolts to the chassis and I have it right around 14". According to QA1's website, the shocks I have only have a 13.5"-21" length (compressed/extended).
You can see here the car years ago. This was the stock ride height front and rear:
https://static1.pt-content.com/images/pt/2010/02/Olds01-1.jpg
https://static1.pt-content.com/images/pt/2008/05/wheels_3-1.jpg
It looks about 2" too high to me.
