bochnak
01-06-2010, 04:46 AM
Power Performance (PP) has sent me tall upper & lower ball joints for free. In return, I agreed to install them and post install pics.
The car is a 70’ Chevelle with the following changes from stock:
SPC upper control arms with BJ spacer kit. Spacer kit is required when running stock height BJ’s. This will allow enough suspension droop.
600# circle track springs
Varishock single adjustable shocks
ZQ8 bumpstops
18” C6 wheels up front
Lowered – LCA level
My car still has drum brakes, therefore a tall lower BJ can not be used. I’ll show why later. I used a spare set of drum spindles less brakes for the install. I had 14” wheels on the car until I ran into an interference issue with the SPC UCA’s with BJ kit and wheel weight. I know that most people are probably past the 14” wheels and drums brakes, I just thought I’d mention it since we have different starting points.
I have bought some cheap stock replacement BJ’s from Autozone to illustrate the height differences. Both the upper and lower BJ studs are ½” longer on the Power Performance BJ’s.
Upper ball joint (Stocker is on the left, PP on the right)
https://static1.pt-content.com/images/pt/2010/01/DSC_6847JPG-1.jpg
Lower ball joint (Stocker is on the left, PP on the right)
https://static1.pt-content.com/images/pt/2010/01/DSC_6846JPG-1.jpg
Here is a pic of spindles w/BJ’s sitting on top of my workbench. Stockers on left, PP on the right. Notice how the effective spindle height increases by an inch, steering arm is raised by ½”, and car will be lowered by ½”.
https://static1.pt-content.com/images/pt/2010/01/DSC_6843JPG-1.jpg
PP upper BJ installed
https://static1.pt-content.com/images/pt/2010/01/DSC_6813JPG-1.jpg
PP lower BJ installed
https://static1.pt-content.com/images/pt/2010/01/DSC_6852JPG-1.jpg
Some final pics:
https://static1.pt-content.com/images/pt/2010/01/DSC_6862JPG-1.jpg
Why drum brakes will not work:
https://static1.pt-content.com/images/pt/2010/01/DSC_6810JPG-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSC_6856JPG-1.jpg
You can view more pics here:
http://picasaweb.google.com/mbochnak/TallBjS?feat=directlink
ZQ8 bumpstops
Lowered – LCA level
Some final pics:
