Chicane 73
12-27-2009, 09:15 PM
We are in the final stages of finishing the suspension work on my Challenger. The alterKtion front system went very smooth. Using QA1 with Wilwood brakes in front Chevy bolt pattern. Will run 17"x81/2' in front. No decision on wheels yet. Flaming River rack and pinion steering, and sway bar. Sub framed to beefed rear frames where I was going to use a Team 321 rear end which I waited a year for and when I received the "custom"rear end we could not use it without hashing the car,badly. I opted for a Jag XJ12 rear. We modified it,left it in the cage so the geometry would not be changed. The entire unit comes out on the ground with three bolts on each side,undo the custom control arms and the brake lines and that is it. Very pleased so far.
My question is,has anyone put Wilwood brakes on a Jag rear end? I think I need more brakes than the stock setup affords.There could be other solutions some of you might know also. I originaly thought all I would need was to go with all new Jag brakes but I don't think they are enough for this application.
Any help you can give me will be most appreciated.:help!: Thanks.
