View Full Version : Problems installing Ford 9-inch axles... help!
davepl
12-27-2009, 06:17 PM
I'm trying to put together a Currie crate nine (and don't even get me started on a "crate" package that requires a machine shop or arbor press), but I can't seem to get the bearings pressed on far enough.
I'm using a 12-ton arbor press and it comes to definate stop at about this point on both axles. I know its not going far enough because if I mock it up, the brake drums don't reach far enough back.
I've been on this all day and I'm desperate... any ideas would be great!
Dave
Photo:
http://www.flickr.com/photos/22171525@N00/4220176285/ (http://www.flickr.com/photos/22171525@N00/4220176285/)
davepl
12-27-2009, 07:25 PM
I wound up putting them back in the press, using the extension handle, and I figured I'd crank until they seated or the press exploded and killed me. Fortunately, the former happened.
I'm still pretty bitter that a "crate" rear end doesn't have the bearings pressed on or include any fasteners or gaskets! I've live close to Randy's ring and pinion too, serves me right for not dealing locally I guess!
silver69camaro
12-28-2009, 06:07 AM
Honestly, I've never seen the bearings pressed on the axles before from the manufacturer. It takes a decent press to get the things on (we use a 20-ton), and use lots of anti-seize.
ibuildm
12-28-2009, 08:03 AM
Next time try Dutchman Motorsports in Portland. They have all types of housings and will install the bearings at no charge. When you buy a complete rearend with axles and third member they include all the mounting hardware, seals and gaskets. Their prices are good too.
Tim
wmhjr
12-28-2009, 09:19 AM
When I bought my Moser crate it had the bearings already pressed on the axles when I received it. I spent far more time prepping and painting the rear end than I did assembling and installing it. Got it through Frank at Prodigy - good service and pricing.
MonzaRacer
12-28-2009, 08:23 PM
never tried to press bearings with arbor press always used hydraulic press
CarlC
12-28-2009, 10:19 PM
I recommend not using anti-seize on bearing shafts or housings. The metals used in most anti-seize compounds can cause fit problems. A light hydraulic oil is sufficient.
LowBuckX
12-29-2009, 01:07 AM
I use redline assembly lube when pressing anything now.. Great stuff
ProdigyCustoms
12-29-2009, 03:47 AM
As WMHjr said, our Mosers come already pressed on and only need bolted in.
silver69camaro
12-29-2009, 06:12 AM
Can you explain? Never had a problem in the past...
killer69
12-29-2009, 08:15 AM
our "Crate" rears come fully assembled. axles and center section installed.
Sorry Matt
but your correct they are REALLY Tight!!
silver69camaro
12-29-2009, 08:35 AM
Sorry Matt
That makes sense, I've never ordered a complete axle assembly before...just axles.
killer69
12-31-2009, 08:21 AM
Matt lets be honest all you have to do is walk into the shop and grab a set ............. that is why you have never ORDERED any
:enguard: hahahah
