View Full Version : Any ideas?
683504SPD
12-13-2009, 06:23 PM
I converted to Pertronix Ignitor ignition in my 68 Chevelle.It ran absolutely awesome until I changed the alternator out with one I had laying around.After I changed it the car runs like crap,it's popping and sluggish.A couple people said it might be the module got shorted out.What do you think?Thanks in advance.
683504SPD
12-21-2009, 05:29 PM
I find it hard to believe that 56 people have looked at this and no one has anything to say.
mjoc1
12-22-2009, 01:03 AM
Try buying a new module if it works it is the module if not return the module.
Mike
Is the new alternator charging. Could be as simple as running low on voltage. Should be charging 13.8-14.2 runnning around 1200-1500 RPM.
TT302Z28
12-22-2009, 07:38 AM
I agree with MJOC1 except that usually when the module goes it doesn't work at all. Try using a meter to check voltage at the coil and at the module. I would also want to see what the alt is outputing.....do you still have the other alt? Try putting it back and see if the problem cleans up.
Speedbump
12-22-2009, 09:10 AM
Mike
I like this... except the part about trying to return the module. Most parts houses around here don't allow you to return electrical stuff (condensers, modules, voltage regulators, etc.) I do keep a module in the trunk for exactly the reason TT302Z28 said (usually when the module goes it doesn't work at all). I have been stranded once before this way.
1994 Python
12-28-2009, 11:51 AM
Gotta agree with SpeedBump. Around here you can only return electrical parts if they are still in the plastic and unopened.
X2 on the alternator. Seems like the likely culprit to me.
683504SPD
01-03-2010, 06:28 PM
Thanks for the input guys.I ran some tests this past week and the ignition module tested fine according to my meter and testing info from pertronix,also tested the coil and that seems to be fine(about 2.5ohms).Now I'm not sure where to go,maybe plug wires or possibly a fuel issue?
79ZED
01-16-2010, 09:07 PM
Why did you change the alternator? My guess is the replacement alternator has a bad diode and is putting a lot of noise or voltage spikes into the electrical system, which is probably not making the Pertronix Ignitor too happy.
John
TT302Z28
01-18-2010, 10:06 PM
If you disconnect the alt, does the problem go away? This might be a simple test to see if it is the alt that is giving you these problems.
This really sounds like it could be a bad ground too.
garner67
01-18-2010, 10:13 PM
+1 Check your ground(s).
