View Full Version : LCA bushings out
malibu43
12-01-2009, 09:22 AM
hi there,i ve just inspected my 80 bu,and i found out that the lca (rear one) bushing(at the frame side) went out,i mean its out of the lca hole.
why this its happening? its the second time happen.
regards
pleas explain in plain english.
John Wright
12-01-2009, 10:58 AM
Maybe the hole in the LCA is too big for the bushing?
malibu43
12-01-2009, 03:01 PM
i dont think so,because are the stock ones,and i dont know how that can getting bigger,or maybe for the use?
thanks
85GPLEf41
12-01-2009, 11:08 PM
What kind of bushings are they?
79T/Aman
12-02-2009, 02:18 AM
stock control arms? well yes the hole can get too big, they are stamped sheet metal after pressing bushings in and out a couple times the hole will get bigger, and if you have been doing some spirited driving the twist on the control arm will oval the hole and pop the bushing out.
malibu43
12-07-2009, 10:04 AM
yeap guys,thats its my problem,i do race my 80 bu as a road course,and i make heavy right and left turns,but how can i counteract this problem? any help will be apreciated
regards
jorge
79T/Aman
12-07-2009, 10:29 AM
tubular trailing arms with spherical bearings will solve your problems
malibu43
12-07-2009, 05:46 PM
got it,and thank you vey much.
TitoJones
12-07-2009, 05:49 PM
You could try and tack weld the bushing sleeve to the arm as well for a temp fix if you plan on using those bushings.
Tyler
malibu43
12-08-2009, 08:28 AM
TYLER i allready did that but they coming out anyway.
thanks
exwestracer
12-09-2009, 05:18 PM
Those metric cars werent the greatest about aligning the LCA mounting holes. This causes the bushing to flex as the control arm cycles. Combine that with heavy compression loads from cornering forces, and that may tend to "walk" the bushing out.
I built some IMCA modifeds off those chassis way back when, and I always had to take a long drill and run all the way through the LCA axis to get solid bushings to work.
malibu43
12-10-2009, 01:11 PM
can you explain me much better how to fix that issue? some pics?
regards
