View Full Version : Pictures in Thread
SDS MACHINING
05-07-2009, 09:43 AM
I am looking for assistance with posting pictures in the thread, not the typical thumbnail, but the larger pictues I in other threads.I already have a fquick and photobucket acccount set up, what am I missing?
crazyfireman
05-07-2009, 10:15 AM
You need to use your photobucket account then copy the img code and paste it on your thread.
crazyfireman
that is what I did above..
derekf
05-07-2009, 10:16 AM
Yep, like CFM said - when you upload pics to photobucket it should give you several different tags to possibly use for various forums; this is vBulletin so the image tags look like [ IMG ]path to image[ /IMG ] (without the spaces).
BonzoHansen
05-07-2009, 11:32 AM
See if this helps: http://www.nastyz28.com/forum/showthread.php?t=90720
You should use the THUMBNAIL option in photobucket.
SDS MACHINING
05-07-2009, 02:49 PM
i will give it a try..
thanks everyone,,,
SDS MACHINING
05-07-2009, 03:33 PM
https://static1.pt-content.com/images/pt/2009/05/DSCN0186-1.jpg
SDS MACHINING
05-07-2009, 03:34 PM
worked great, thanks everyone for there assistance
thetoystore
05-09-2009, 10:56 AM
why is it that when i try to upload pics its says i am above my quata?
derekf
05-09-2009, 08:05 PM
why is it that when i try to upload pics its says i am above my quata?You, as a regular member, only have so much space to attach pics to your posts. If you're getting that message, you must be getting close to your limit.
You can:
Remove attachments from old posts
Become a "site supporter", which gives a larger quota,
or
Host the pics on Photobucket or the like and just link them here (as noted above).
