View Full Version : TFX Fuel Injectors
12-09-2008, 08:44 AM
Trick Flow Expands Line of TFX Fuel Injectors
http://www.trickflow.com/pressreleases/TFXFuelInjectors/images/TFX-Fuel-Injectors.gif Download this image
in hi-resolution. (http://www.trickflow.com/pressreleases/TFXFuelInjectors/zip/TFX-Fuel-Injectors.zip)
AKRON, OH—In 2007, Trick Flow Specialties unveiled a new line of performance fuel injectors that deliver better fuel atomization, high operating efficiency, and quieter performance than other aftermarket fuel injectors.
Now, the Akron, Ohio-based company has expanded the line to include the following new flow rates: 44 lbs./hr., 55 lbs./hr., 72 lbs./hr., 83 lbs./hr., and 95 lbs./hr.
"In response to the huge demand for our TFX fuel injectors, we've added additional flow ratings to our selection," Al Noe, Trick Flow Manager, said. "Our customers can now choose from ten different flow ratings to meet their performance requirements."
Also available in 24 lbs./hr., 30 lbs./hr., 36 lbs./hr., 48 lbs./hr., and 120 lbs./hr. flow ratings, TFX Fuel Injectors feature disc-type fuel control valves and improved nozzles to atomize fuel better. Low magnetic stainless steel injector bodies prevent corrosion from underhood contaminants and seal the injectors from moisture contamination.
The injectors have EV1-style wiring connectors which match the OE wiring harnesses for an easy, positive connection. Viton fluoroelastomer O-rings seal the injectors to the fuel rails and intake manifold to prevent fuel and air leaks under extreme operating temperatures. TFX Fuel Injectors also include 1/2 micron filter screens to keep debris out of the injectors.
The injectors are part of Trick Flow's line of TFX Fuel System Products, which includes fuel filters, fuel pumps, fuel regulators, fuel fittings and hose, and nitrous systems and accessories. For more information on TFX Fuel Injectors--and the entire Trick Flow TFX product line—you can call 1-330-630-1555.
Based in Akron, Ohio, Trick Flow Specialties offers products that provide "Ultimate Bolt-On Performance." Trick Flow's product lines include cylinder heads, intake manifolds, camshafts, valvetrain components, nitrous systems, superchargers and more, visit www.trickflow.com for more information.
*Viton is a registered trademark of DuPont Performance
