View Full Version : Do I need to use a balast resistor on the MSD ignition?
Rileys68Camaro
02-25-2005, 06:52 PM
On my Painless Wiring harness instructions, it says to use a ballast resistor between the power wire and coil.
But I'm using a MSD Blaster 2 coil with the 6A box and pro billet distributor and MAD electrica upgrade wiring parts.
zbugger
02-25-2005, 07:47 PM
Check the wiring diagram that comes with the MSD ignition box. I really don't think you need it. The resistor is only necessary on old school points style ignitions. The MSD stuff isn't. It's more like a HEI style ignition.
novaman_68
02-26-2005, 08:40 AM
No you don't need it, the ballast resistor wire is for the points style ign. coil.
Rileys68Camaro
02-26-2005, 12:24 PM
Thanks!
I didn't thinks so but wanted to make sure.
