bulldog19
05-20-2008, 05:48 AM
I installed a full TVSS Kit on my 68 camaro convertible. The car is a small block with aluminum heads. My question is that i don't think that i got the drop that they advertise. My first question starts with the rear suspension. I'm running a 17" rim, TT 2's with 285/40 tire that measures approx 25-1/2" tall and the distance from the ground to the center of the wheel opening is 27-3/4". If i went to a multi leaf shock plate from the stock monoleaf plate would this change the distance from the tire to the fender? I don't know what backspacing rim i have so i don't know if i will have clearance issues. The front is the same issue. I'm running a 235/40 tire on 17" rim but it is a different series goodyear, it's 23-1/2" tall and the distance from the ground to the center of the fender lip is 26-3/4". I'm missing some weight on the front end, hood is currently off, power steering pump and a/c compressor. But would this make that much of a difference in the height? What are my options to try and close the gap? Will an 18" rim/tire set up change the space? The car is a black convertible with pearl houndstooth so i'm also looking for some rim finish/color suggestions? do i have something installed wrong?
Thanks for the input.
