67 caprice
02-04-2005, 02:13 AM
Has anyone used the FAST ecu fan control with the dccontrol?
FAST ecu has a fan connection; you can set the temp via ecu to turn the cooling fan on and off. I like the idea that the dc controller can control the speed of the fan. Should I use the dc controller with the FAST ecu? Or should I bypass the FAST fan output, and wire the dc controller direct?
Russ
Russ
