ProBell
04-02-2008, 04:50 PM
I had my spindles magnaflux today. I had one on the car that was cracked and one of my spares was also cracked. I am looking to fill out the this form so I can send it out to see if some one can build a custom spindle that is close to the same geometry.Thanks for the help. Randy
Fabricated Spindle Spec Sheet
Please Print This Worksheet To Provide Us The Correct Specifications For Your Spindle
A = Kingpin Angle ____________B = Offset________________
C = Spindle Drop __________D = Spindle Length ____________
E = Steering Arm Length ______________
F = Steering Arm Drop ________________
G = Ackermann Neg. ________H = Ackermann Pos. _________
I = 2.3125" (2 5/16") Upper And Lower Ball Joints Are The Same (727, 772)
Spindle Snout Type _______________________
Type Of Ball Joint - Upper __________________
Type Of Ball Joint - Lower __________________
Type Of Hubs ______________________________
Rotor Thickness _______________Diameter ______________
Caliper Type - Front ______________ Rear _______________
