gmachinz
01-21-2005, 04:42 AM
I have a few FK-35's left if anyone else is interested. In case someone might not know, these are designed to be used with high current electrcic fans to aid in maintaining a constant engine temp (180). instead of merely turning on and off via a thermo switch which does nothing to control amperage use as well as a progressive controller. For example, Lincoln Mark VIII's use (among a couple other things) engine coolant temp readings and the computer dictates how much voltage goes to the fan-this helps extend alternator life and the engine temps aren't constantly moving up and down all the time. If there is any questoins regarding these kits and others from DC Controls-shoot me an email-I have some good suggestions if you are going with a high current fan and are unsure of what is needed. -Jabin [email protected]
