View Full Version : Upper Control Arm Shaft - What to torque to?
eville
07-09-2007, 08:59 PM
I have a set of SpeedTech UCAs for my 68 Camaro.
The instructions did not mention a torque spec for the UCA cross shaft bolts... what should I torque them too?
Lowend
07-10-2007, 12:16 AM
The shaft-to-frame bolts are 85 ft/lbs on a 2nd gen
jknight16
07-10-2007, 08:28 AM
I was just talking to Mark at SC&C about a similar topic today. He recommended 60 ft/lbs for the 7/16 grade 8 bolts I'll be using on my SPC upper control arms, would be closer to 80 ft/lbs if you were using 1/2 inch grade 8 bolts.
eville
07-10-2007, 09:23 AM
I emailed SpeedTech and they said adjust them like a wheel bearing, snug it up and insert the cotter pin.
6'9"Witha69
07-10-2007, 09:41 AM
I think the responses differ from the question here. eville, you are talking about the specs for the ends of the cross shaft correct? Where the UCA bushings are? Then yes, it is like a wheel bearing. The shaft to frame bolts require a torque spec as noted above.
eville
07-10-2007, 09:54 AM
Yes, they are actually nuts, at the ends of the cross shafts next to the CA bushings.
6'9"Witha69
07-10-2007, 09:55 AM
Yes, they are actually nuts, at the ends of the cross shafts next to the CA bushings.Yeah, my GWs with Del-a-lum are the same way. You have the right info now.
