View Full Version : Need a carb Recommendation
king67rsss
12-05-2006, 11:09 AM
I'm pretty much clueless as far as how to choose a carb and what model to get. The engine builder mentioned that he used a 700 Holley Double Pumper but I'm not sure that is the right carb for a non- raced, weekend driver.
Here is my combo:
Pontiac 400 .030 over
Cast Crank .010 mains/.010 rods
Speed pro forged pistons
Cam- Ram Air IV with 1.5 rockers
Intake Dur. 308 -open 42-close 86 -lift .469
Exhaust Dur. 320- open 95- close 45 - lift .469- overlap 87
Heads- #15 castings 9.0 to 1 on 400 Pontiac
Intake- Edelbrock Pontiac Torker II
400 trans with 3.73 gears in a 8.5 rear
6'9"Witha69
12-05-2006, 11:16 AM
The 700 size sounds good but I think for drivability a Vac Secondary would be better.
king67rsss
12-05-2006, 11:46 AM
doesn't the Holley Double Pumper come with Mechanical secondaries?
6'9"Witha69
12-05-2006, 12:53 PM
doesn't the Holley Double Pumper come with Mechanical secondaries?Yes, double pumper is the nickname given to a Mech Secondary carb due to the 2 accelerator pumps (primary and secondary).
king67rsss
12-05-2006, 01:28 PM
Looking through Jegs and Summit, I don't see any 700 carbs that have vac secondaries. Could you point me in the right direction?
thanks
Shaker455
12-05-2006, 04:02 PM
King,
I build custom carbs and I have a 71 T/A 455HO
What are you running for a stall converter?
Considering your running an open plenum T2 intake I'd recomend a 4- hole spacer and a double pumper, 4 corner idle mech sec 750 as a vac sec carb will not feed your engine as well as a 4-corner unit with with an open plenum.
Also I can build you a nice HP style 750 dialed into you engines requirements.
dhardison
12-05-2006, 05:37 PM
The holley web site has an interactive carb selector (top right corner of the main page). Never tried it but it can't hurt to enter your info and see what comes out the other end. If you do, please post the selector's recommendation. I'm curious to see what it recommends for your configuration.
http://www.holley.com/
king67rsss
12-05-2006, 06:24 PM
Thanks Dan, The Holley site recommended the following:
0-80508S 750 CFM Four Barrel Street Carburetor 750 CFM Four Barrel Street Carburetor
Electric Choke; Vacuum Secondary, Model 4160
OR
0-80770 770 CFM Four Barrel Carburetor 770 CFM Four Barrel Carburetor
Electric Choke; Vacuum Secondary Street Ready out of the box; Two adjustments and go
Shaker455
12-05-2006, 07:43 PM
King,
You got mail
68Formula
12-06-2006, 04:01 AM
OR
Had I seen your thread earlier, I would've recommended these as well. I like vacuum secondaries for mostly street driven too.
Tom Welch
12-07-2006, 06:06 PM
HAve you considered a custom Q-jet? Cliff Ruggles can build you an excellent unit. He's on the net. First class work.
Roger Poirier
12-10-2006, 04:37 PM
King,
My own experience, less is better for a Pontiac engine. 750 cfm is more than enough. Chances are your going to have to have the carb re-jetted along with other small changes. I have a 428, 60 over with Ram Air IV heads. My carb is a Barry Grant 750 cfm DP. They had to downsize my jets along with other changes. Getting that carb tuned is critical to getting a Pontiac to run properly. Go with somebody that knows what they are doing.
R.P.
Roger Poirier
12-10-2006, 04:51 PM
King,
R.P.
Shaker455
12-10-2006, 06:57 PM
R.P.
Roger,
I've been into Pontiacs all my life and been building carbs for Pontiacs for years as well as tuning, a well built 750 will feed his engine perfectly and I have done so with other 400's with great results.
A 750 is the standard size for most Qjets fitted on these engines stock so I'm not sure what experience you have if I read your responce correctly..... you sent your 750 back to BG to have them simply change jet size??
Roger Poirier
12-10-2006, 07:57 PM
Roger,
I've been into Pontiacs all my life and been building carbs for Pontiacs for years as well as tuning, a well built 750 will feed his engine perfectly.
Also a 750 is the standard size for most Qjets so I'm not sure what experance you have?...I do like your combo though!
I'm agreeing with you. You put an 850 on a street 400 Pontiac and it will run very, very rich. I know from my own experience. Purchasing out of the box will get you started, however changes always have to be made.
R.P.
Shaker455
12-10-2006, 09:14 PM
I'm sorry Roger as I said I must have not read your post correctly.
Tell me more about your combo?
My friend out here Lenny Caverly who competes in Enginemasters has a 458 Pontiac that he runs on the street/strip: 428 block, 455 crank, BME alum rods,flat tops,RAIV heads ported, 11.4:1 custom solid roller he designed to run on pump gas....runs awsome and does 11's
Zee
12-11-2006, 01:46 AM
King, Let Shaker build a carb for you. You won't be dissapointed.
Roger Poirier
12-11-2006, 01:40 PM
King67RSSS, this may help you in your next build process. Or maybe not?
I had a Ram Air III 400. There just was not enough power for me. I went to the big guns, however still wanted to stay with a Pontiac engine. This is before stroker engines became popular.
428 4 Bolt Mains - Bored .60 over
Ported and Polished Ram Air IV Heads (milled aprox .020)
Forged Rotating Assembly
Edelbrock Torker Manifold, Ported and Polished 1" Spacer
Barry Grant 750 DP
MSD Ignition
Hyd Ram Air IV Cam 1.65 Rockers (Close to those specs.)
2" Hooker Custom Headers with X-pipe and 2 1/2" in exhaust.
4.10 Rear Gear
TKO 5 Speed
R.P.
Tom Welch
12-12-2006, 05:14 PM
For Pontiac guys, Jim Hand is considered an expert on tuning and building for performance. Cliff Ruggles is the same in this respect. Jim Lehart is also very well respected in the Pontiac community. All of these guys would probably recommend a well built and tuned Q-jet for a Pontiac engine that will see street driving. All of these men can be corresponded with on the Pontiac Street Performance website. Jim Hand and Cliff Ruggles have authored books on this very subject. Both are very valuable for us Pontiac peeps.
pitts64
12-28-2006, 04:49 AM
Cliffs custom Quadrajets are well proven.
I have one on my 462 and it runs great.
http://www.cliffshighperformance.com/
IMO you have too much cam for a 9 to 1 400. I would try a Crower 60916 or at least add Rhoads lifters to the ra-4.
critter
12-28-2006, 05:52 AM
Hey, Shaker is here and helping so don't walk away from him. I know his reputation via some Pontiac BBS systems and he does good work. Cliff is doing my carb but that's because I know him. Either one will do a good job for you I'm sure.
Shaker455
12-28-2006, 12:09 PM
Hey Critter,
As you may know I'm also friends with Cliff and I am working with King on his engine combo as well as building him a custom Holley.....
I also offer fly & tune service and I may be going to dial in Kings combo in person.
critter
12-28-2006, 01:59 PM
Yes, I gathered as much from the postings I'd seen. Fly & tune, lol, sounds like a good deal. Good luck with it.
hectore3
12-28-2006, 08:08 PM
I am having Shaker455 build me a proper carb my for my Pontiac 428 engine also. He is a good guy. I recommend him highly. It's a good deal for me since he is near my parents house in New hamshire.
Does not have to "fly" very far to help me tune this thing once I get the custom roller ground among other machine work. :jump:
MonzaRacer
03-23-2007, 06:44 PM
Dont worry about the RA-IV cam it isnt super high lift, The compresssion is fine, heck I ran similar cam ,slightly more lift same other specs, and my engine was computed at 8.6 to 1. Ran great and never gave me a problembig trick is get a good converter or Switch Pitch 400, for street use most RA-IV cammed engines can get away with TCI Saturday Night Specials (bare minimum for any cammed engine in my opinion.
OH and as for the Rhoads lifters,,, wouldnt do it in a Poncho, had them ,never liked them in it.
Good luck
