bingham72
10-22-2006, 09:31 AM
Engine Specs...
350 smallblock chevy
Stock Distributor
Crane XRi-1 points conversion
MSD Blaster 3 coil
Here's my issue. i've been trying to get my car to run consistanly. it has been started and even driven. However, it wouldn't idle below 1000 RPm. Now, it won't even start. I get a spark from the coil to the dist cap, but NO spark from the cap to the plug wires.
Is the spark grounding out somewhere? Is the rotor bad?
How else do I test this? all the parts are brand new.
I also figured out that the Blaster 3 coil isn't meant for non-msd ignition, so I haven't tried going back to the stock coil.
But if that's the case, why did it start before?
Thanks is advance!
Drew Bingham
Stock Distributor
MSD Blaster 3 coil
Thanks is advance!
Drew Bingham
