View Full Version : Install a temp gaue with no bug
68 SuperRam
09-22-2006, 03:06 PM
Is there a way to install an electronic temp sensor for a transmission - but not in the pan - no bung? Is there any way to do it in-line with the cooling lines?
JJSmitches
09-22-2006, 03:23 PM
I installed mine using a T-fitting. The temp sensor screwed in using an adapter. Cost, about $30.
rocketrod
09-22-2006, 04:22 PM
Try one of these
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM%2D2286&N=700+115&autoview=sku
Modo Innovations
09-24-2006, 08:04 AM
Try one of these
This is what I planned on using also.
ProBell
09-24-2006, 09:50 AM
It is not that hard to add the bung to the pan. If you add a bung you will end up with a lot less points that can leek or fail and you do not need to mount any extra parts. It also adds a drain point if you do not have one already. Just my .02$. Randy
68 SuperRam
09-25-2006, 04:06 PM
That was my original intent - however the tranny shop that built my new tranny - forgot to put a bung in for me - which got me upset - really do want to take apart the new pan - and break the seal and redo - just want to get it in the car - reason why I was looking for another alternative to a welded bung.
Thanks guys - that autometer part is exactly what I will need.
