View Full Version : LS1, T56 on a 72 camaro
72Z/28
09-01-2006, 05:11 AM
Hi guys, I am thinking of getting a pullout LS1, T56 for my 72 camaro, it is a 4 speed. I have checked the BRP conversion kit for a 2nd generation camaro, and all they have listed are motor mounts and crossmember. I know i need to get a wiring harness and stuff, but is there anything else i need to modify?? I need to keep the AC as well. I have the serpentine belt, compressor, water pump, alternator, marche pulleys....on my car at the moment..
I would appreciate it if there are photos of 2nd gen camaro with the LS1 conversion.:thankyou:
jsconiers
09-09-2006, 12:49 PM
for pictres and more information go to ls1tech.com. there is a forum called hybrids. Unless you want to cut out a shifter hole location you will also need the mcloed slik stix shifter. you may need to slightly modify your ac setup but not much would change.
Rybar
09-09-2006, 01:08 PM
Check the links in the attached signatures, all these guys are/were doing the swap: http://www.ls1tech.com/forums/showthread.php?t=546878
