View Full Version : Leaky Chrome parts... What parts do I switch to?
Joe_Rocket
10-28-2004, 09:48 PM
Hey guys,
When I built up my small block chevy, I got a chrome dress up kit. It's cheap and warps. I was just a kid and didn't know any better. The oil pan leaks pretty bad.
I'm wondering what's a good solid oil pan, and timing chain cover that won't warp from tightening the bolts.
10-28-2004, 10:16 PM
I've been running with cast aluminum parts lately, several cast pan makers out there. The Comp 2 peice timing cover is great too. The 2 down sides are not impact friendly and cost more $$$
pushrod243
10-30-2004, 07:03 PM
In the past ive had good luck with Moroso stuff. Its a reasonably priced alternative.
TurboLark
10-31-2004, 09:29 AM
Simple answers.. Use a cast timing cover and valve covers. Plenty available. For the pan, buy a one piece rubber gasket that has steel inserts at the bolt holes. Then you can tighten down without crushing the panrail or gasket. I'm using Felpro number OS34500R. I got it from Summit.
