View Full Version : Who can do LS1 harness/pcm mods?
68ls1
10-06-2004, 10:36 PM
Gents, I posed this question on the old website and was given the following e-mail address. ddash@ma.rr.com. I just recently got around to it and have had no response for over a week. Can someone direct me to a company or individual that is able to perform the mods necessary to swap the LS1 into my Camaro. I would like to have all the uneeded wiring removed (emmisions etc...) and have the pcm re flashed so I can get it running.
Thanks, Noel.
LS1NOVA
10-07-2004, 03:43 AM
SPEARTECH IS YOUR MAN. WWW.SPEARTECH.COM
68ls1
10-07-2004, 04:44 AM
Thanks for the tip. From the looks of that site, it's an extra $300 for a 'prettier' harness, am I about right on that one? LS1NOVA which way did you go? Redoing your factory piece or buying the custom harness. Is the factory harness long enough to place the pcm in the glovebox on a camaro?
LS1NOVA
10-07-2004, 07:32 AM
I Dont Think The Factory Harness Is Long Enough. I Mocked One Up And You Could Maybe Reach The Inside Of The Firewall But Probably Not All The Way To The Glovebox. I Will Probably Sell The Factory One And Have Speartech Make One. It Looks Nicer And He Can Do Any Custom Options Like The Truck/ls6 Mas Or A 4l80e, And Can Make Any Lenghth. I Think It Would Be Worth The Extra Money.
MuscleRodz
10-07-2004, 02:35 PM
I would look at Painless for your harness needs. If you are running stock motor then the stock pcm will be fine. If your motor is modifed I would contact Ed Wright in Tulsa. He is suppose to be the best in the midwest.
Mike
LS1NOVA
10-07-2004, 04:42 PM
The downsides of the Painless harness is they come with all the emissions wiring also, which you may or may not need. A harness looks a LOT better without the rear o2's, egr,etc. Perrsonally i dont like extra wiring laying around not plugged in. Also you have to use a 98/99 PCM. Although it is a couple hundred bucks cheaper. In this situation, I definately think you get what you pay for.
malibu9in
10-09-2004, 06:49 AM
fuel injection specialties in san antonio hands down
andrewb70
10-11-2004, 10:02 AM
Dana Dash did my harness for the RX7. Fast turn around and fair price.
http://www.lt1350.com
68ls1
10-12-2004, 10:39 AM
Dana Dash...thats the name thats been on the tip of my tongue. Now I recognise the lt1350.com So Andrew was it nice work?
Thanks, Noel.
andrewb70
10-13-2004, 06:57 AM
Dana did a fine job. I just had him rework the stock harness. He added the fuel pump and fan relays. He also added a pair of rear O2 sims as well as a VATS disable module and CAGS module. The harness was also double checked to make sure nothing was shorted out or cut. The car started on the first crank. It scared the s**t out of me.
He does most of the harnasses for the guys doing the Mazda swaps. I have yet to hear any complaints.
Samckitt
01-16-2006, 06:44 AM
Noel,
I second the nomination for Speartech. He lives about 35 miles from me & did my LT1/T56 harness for an 86 Monte. He modified the factory harness for me. I wish now I would have had the custom harness made. He will make it to your requests. Remove whatever you don't need or want, and has connections for gauges if needed, SES light, & so on. He can also reprogram the PCM for engine upgrades, removal of emissions, & removal of skipshift.
John (owner of Speartech), worked for Delco/Delphi for years in the engine room. He made harnesses there for the engines on the dyno & for the ones being used to cycle test starters.
Just my $.02.
Scot
Noel, email me @ smckitt@verizon.net I have some questions for you.
Tennessee Auto
01-17-2006, 09:18 PM
If you got the room to mount the pcm out side the car, and the bulky wiring is not a problem contact Dana. If you wanting a custom harness John at Speartech makes a really nice clean, and small harness. We have also been using a guy from FL (Jerod) for some custom made stuff. As you can see on the trucks we had room, and used the factory harness. On Mark's 69 Cmaro we wanted something hidden, and John hooked us up.
Thanks Scott
BTW: Scot it's good to see the SS again.
http://site.tennesseeauto.com/pics/3415.JPG
http://site.tennesseeauto.com/pics/3453.JPG
http://site.tennesseeauto.com/pics/3428.JPG
gEtyOpAPiOn
01-18-2006, 07:03 PM
well you can do it yourself if you ha patience ....is not that hard ...the emission wires are easy to remove too the best ones i seen were wrapped with shirnk wrap i think it was f.a.s.t ...but be ready to pay hehe
Damn True
01-20-2006, 12:06 AM
Anyone on the left coast?
gEtyOpAPiOn
01-20-2006, 12:08 AM
Ya Need Help ?
Damn True
01-20-2006, 12:35 AM
Not yet. In fact I'm still flipping coins on Gen I vs LSx. Just trying to flesh out my contacts & information notebook.
When the time comes I will be hitting up a number of folks for help. The pay is good (Kathy's cooking). There is a really good reason why Ive gained 20lbs in the two years we've been together.
Steve1968LS2
01-20-2006, 06:16 AM
Another vote for John at Speartech.. he did my '69 and he is doing my '68...
nitrorocket
01-24-2006, 03:41 PM
I did my own harness, believe it or not, it is not that hard. If you get a wiring diagram you can easily pick off all the unecessary wiring. I can also tell you exactly what wires to ditch if needed. Most of the wiring will be removed if you are ditching all the emission stuff.
I can do your pcm mods if needed. I use Efilive Flashscan. I tune cars including my own twin turbo ls1 with speed density and 96 lb/hr/ injectors.
Let me know if I can help.,
http://i8.photobucket.com/albums/a50/nitrorocket/_DSC0005.jpg
ertoys
02-22-2006, 02:41 PM
I am impressed!
Steve68
02-22-2006, 03:29 PM
Where and who is Jerod in FL, I'm interested
CarlC
02-22-2006, 06:55 PM
Nice work.
Who's wiring diagram do you suggest? Also, do you know of a supplier for the crimp connectors? I'd rather do this than cut-sodier-splice deal?
nitrorocket
02-24-2006, 09:34 PM
ALl you need is the pinout chart for whatever year pcm/harness you are doing. Torquecentral had a diagram for my 2000. You can get crimp connectors just about anywhere, but I would solder. That way you know you will never have a short or loose connection.
I soldered and heat shrunk every single splice, I had a few, especially with the injector driver!
ahowudoin
03-11-2006, 07:51 AM
yes speartech is the man!
SPEARTECH IS YOUR MAN. WWW.SPEARTECH.COM (http://www.speartech.com/)
