View Full Version : H2O pump ?
kman67rsss
09-30-2004, 04:27 PM
I have an edelbrock water pump. there is a small, 1/2 inch or so oppening on the top. in some pics i have seen a short length of heater hose running from there to the manifold, other pics i have seen this port plugged. what needs to happen. can i plug it and mount the water temp sensor (electric) in that front hole on the manifold? or do these two need to be jumped together? this is on a BBC by the way. thanks
porschev8
09-30-2004, 04:37 PM
That is the bypass for the water pump. You can plug off the water pump and thread your temp sensor into the manifold but you must drill a few 1/8" bypass holes in your thermostat.
Tim
