View Full Version : steering box adjustment
pontiacbird
01-21-2018, 06:24 PM
I have a steering box of iroc z 1988 on my firebird 1968. when I make the adjustment with the top bolt, the direction is tight and direct. I like it a lot like that.the problem is that only a few kilometers later (5-10 kilometers) the direction becomes less tight and more blurred in the center. I have made the adjustment a few times in the last years and always the same result. I can not understand why it does not keep the tight fit as I would like. it seems to me that it can not be worn out in such a short time?
jetmech442
01-22-2018, 09:53 AM
Tehre is a second adjustment to be made aside from the locknut on top. There is what I think is called a "worm gear preload or thrust bearing preload" adjustment. It is the big hex nut on the input shaft. I followed a procedure on pirate4x4 where he walked through it, and in the end my gearbox was tight and responsive('98 grand jeep cherokee swap). I can't find that link, so here is one that looks like it covers the same thing. PS, it makes all the difference if you have the gear box off the car and on a vise. hope this helps.
http://www.gmsquarebody.com/threads/steering-box-adjustments.11794/
pontiacbird
01-23-2018, 10:03 AM
thank you for this information jetmech442. I also check this part of the box a few years ago.
01-23-2018, 01:13 PM
Is it getting a loose feel when the system heats up to operating temperature?
pontiacbird
01-23-2018, 04:32 PM
i did not notice any difference to cold or hot
01-26-2018, 06:22 PM
The idler arm and lower ball joints have a large effect on steering play. Have you checked them?
pontiacbird
01-27-2018, 06:21 PM
I do not detect lousse in the components of direction / suspention.
I focus on the case because every time I tighten a little adjustment of the top, the direction becomes very very correct, which would not be the case if the problem was elsewhere. but each time the direction becomes a little vague after only a few kilometers and I can not explain this situation .....
thanks for following David.
