Andre.servin
08-08-2017, 09:47 AM
How's it goin, i tried installing some new tubular uppers and lowers on my 65 bel air. The issue I'm having is the ball joint seems to taper to a larger size therefore not letting me install the spindle 100% pressed up against the rubber boot. Lower control arm bolts up just fine.
Im not sure if this is infact a problem or not, so I decided to take some photos and post them and get some input from you guys.
65 Chevy Bel Air (basically the 65 impala) stock suspension except for what seems to be a disc brake up grade from the previous owner, GM stock style upgrade. The Tubular uppers and lowers I bought where Southwest Speed. The spindles are for a 1970 Impala (for the disc brake conversion).
