View Full Version : art morrison camaro subframe
marty69212
04-20-2017, 05:27 AM
Anybody know the length of the shocks on an art morrison camaro subframe? I bought a scott mock frame and trying to make it road worthy!
another69
04-20-2017, 12:15 PM
You mean extended vs collapsed?
04-20-2017, 12:24 PM
Art Morrison made a change in upper shock mount height and width around 3 years ago. My 67 Camaro has the low, Mary's came with the higher mounts. I think it was due to them switching to the Strange shocks.
marty69212
04-20-2017, 05:30 PM
I need the extended length.mine are way too long , have to much travel and are the mounts are dangerous
04-22-2017, 06:40 PM
Most shocks for the front will have 4" travel. Ride Tech makes a 4.1 that's we used.
Installed height for that shock is 12.5"
Extended Length: 14.23"
Compressed Length: 10.3"
Ideally, you should have a little more compression travel than rebound, the bump stop takes up some of the compression travel.
If you use a longer shock on a Art Morrison sub, the coil starts getting too close to the upper A arm & in droop, the upper ball joint will probably start binding.
