aeroocoupe
09-13-2016, 05:27 PM
Hi, I picked up a car that the motor was swaped out and the oil pan is in the way of the sway bar now. I can make it work from behind the front tire near the rack an pinion. The front suspension has tension rods to a bar type lower control arm than to a coilover.
Its a 79 Toyota celica with a 3sge beams motor from an altezza.
I know it is an import but is rear wheel drive and 6spd trans. The motor rev to 8000 rpm and makes 200hp to the tires and is 2000 pounds.
Any help would be great thanks Rob
