70chevellemalibu
08-22-2016, 08:42 AM
So i have been finally driving my chevelle around and i have noticed my steering isnt quite the way it should be.
I feel like there is a "flat" spot every once in a while when sitting still and cranking the wheel to turn right. When driving down the road the car darts to the grooves in the road which makes it a bit hard to control, in addition the steering is tight when turning right but has more play when turning left and the steering is so responsive at times and sometimes not so much. Example going down a cloverleaf and merging on to a freeway. I make the initial turn fine but if i need to make a sharper turn its not a smooth turn it becomes a darted turn.
My suspension fully adjustable UMI uppers with tall upper and lower ball joints, stock lower control arms with all new poly bushings, my front end is all new MOOG parts and my steering is a new rag joint and the box is a Jeep Grand Cherokee Box with the adapters from Lee's and of course i have an alignment that matches UMI specs.
From doing some reading i feel like maybe the box is worn out but the pitman arm play vs the shaft movement is almost identical with no "play".
Where do i start troubleshooting so i can fix this.
thanks
thanks
