View Full Version : Increasing steering effort
1985olds
08-10-2016, 03:05 AM
I have a g body with a 5.3 in it using the factory 5.3 powers testing pump. The car also has a grand national steering box and upgraded to the jeep steering shaft. My question is, the steering feel is vague and the effort is too light. I thought maybe increase the pump pulley size and and slow the pump, but that isn't an option due to space. How can I increase the effort on my steering and get the vague front end feel out?
NOT A TA
08-10-2016, 06:56 AM
Increasing pulley size doesn't work. There are different types of kits to change the pressure or volume that comes out of the pump, here's an example. https://www.summitracing.com/parts/brg-899001?seid=srese1&gclid=CLz0rrD5vMgCFUMTHwod2PAFNw A google search will probably come up with other alternatives.
1985olds
08-10-2016, 07:32 AM
Thanks for the response, I already utilized a kit like the one you recommended and I couldn't find much on google.
chickn
08-10-2016, 02:40 PM
If you have a stock dia steering wheel, try a smaller aftermarket wheel. The smaller dia makes a noticeable difference. I had the same issue with my firebird until I went to a different wheel
F-Body International
08-13-2016, 09:08 AM
Turn One makes an adjustable valve for power steering. You may want to discuss with them on what you can do with what you already have.
http://www.turnone-steering.com/#!online-store/ciui/!/Vari-Flow-Adjustable-Flow-Valve/p/47921591/category=12459196
Heidts.
https://www.summitracing.com/parts/hdt-ps-101/overview/
