View Full Version : another 72 c10
1BAD72C10
08-26-2015, 05:26 PM
Ok guys I am building a short bed 72 c10. Need some advice on my setup and what help anyone might be able to give me. I got the portebuilt center section hotchkis tvs and thinking of going with either viking coilovers or ridetech shockwaves. with a 572 bb and a t56 magnum tranny with a custom built dana 60. I'm gonna be running 20x11 rears with 305/50r20 out back and 20x9.5 with 275/40r20 up front. Is there anything else I should be doing to make it handle better or would be better over all. Thanks,any help is greatly appreciated.
Josh@Ridetech
08-27-2015, 01:01 PM
What kind of rear suspension are you going to do? We've got a trailing arm system that'd work great for you if you don't have something in mind yet. All we would need from you with the Shockwaves are the ride height dimensions. We can build you the correct stroke and make sure everything is set up correctly!
BT68c10
08-28-2015, 11:40 AM
I would consider different tire sizes, a 305/50/20 is 32 inches tall and a 275/40/20 is 28.5 inches tall. That is going to cause a good amount of rake.
